Gestener is jamming
  • adastra100
    • Aug 2009
    • 12
    Gestener is jamming
    We have A Gestetner 3355 that has been jamming every 25 sheets. It almost seems like the fuser rollers aren't turning.. It always jams at E1-E4.
    Does anyone have any ideas?
    Thanks in advance.
  • PinevskiS
    • Jul 2009
    • 284
    Hi.
    Go to SP mode and SMC report ( SP 5990) and in "jam history" you can see where are is JAM (which sensor)
    • adastra100
      • Aug 2009
      • 12
      Thanks, I will try that.
      • Brave Hart
        • Aug 2009
        • 73
        Good luck.
        What? HuH?
        • mikadonovan
          • May 2008
          • 2931
          If you have any doubt that that the fuser is not driving check the fuser motor in output mode. I have had one fail in the past.
          After reading your post again, diregard this post. A failed fusing motor would jam every time and probably throw a sc 531.
          Last edited by mikadonovan; 08-24-2009, 04:14 PM. Reason: reread the original post
          NEVER ASSUME ANYTHING
          • mikadonovan
            • May 2008
            • 2931
            Originally posted by Brave Hart
            Good luck.
            I have also had hot roller gears crack in the past causing intermittant misfeeds. Considering the age of this machine, that is a definate possibility.
