Ricoh 2022 wireless network connection possible?
  • copyaction
    • Oct 2007
    • 991
    Have a customer with a 2022 with network print and scan.
    They now want to connect it wireless if possible.
    Was there a wireless option for this or some aftermarket solution that would work?
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    • unisys12
      • 489
      Try one of these... Wireless Ethernet Bridges, 802.11b 802.11g Wireless Networking Bridge at TigerDirect.com
      or this... Netgear WGPS606 Wireless G Print Server - 54Mbps, 802.11g, USB 1.1, 4 LAN Port at TigerDirect.com
      Basically, take a wireless bridge and connect it to your wireless router and program it to connect to that router. Most all of these bridges come with software that will walk you through this process, so no need to sweet it. Anyway, once you have your wireless bridge set to seek your current wireless network, you then unplug it and plug it into your appliance. Be it a MFP, Tivo, PS3, or whatever. From there, after the bridge finds your wireless network, you turn on the device and BAM! Your online.
      I have set up several of these over the last 6 months or so and it is a lot cheaper and far more reliable than going with the onboard wireless option that Ricoh option.
      sigpic
      The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
      • nmfaxman
        • 1702
        I have used Dlink wireless gaming adapter and lyncsys access point to make them work.
        Most gaming adapters will work with easy setup as long as their router is WEP security.
        WPA security limits the choices to those above.
