Seeking advise regarding MP1600Le
  • goldencup
    • Nov 2008
    • 366
    Hi! I would like to seek some advise for Ricoh Model MP1600LE. I would like to verify if the developer type is Type 28? I don't have an available drum right now for that model (MP1600LE), i would also like to ask if i can use the drum of Aficio 220/270? I've tried to compare the drums physically and there seems to be no difference. Hope you can help me on this matter. Thank you very much.
  • Scott_Lewis
    • Mar 2007
    • 519
    Yup, type 28 developer
    Can't comment on the B039 drum being interchangeable with the 220 type drum.
    • Brave Hart
      • Aug 2009
      • 73
      DEV type 28 is correct and you can use the drum of a 220 but not the drum blade.
      What? HuH?
      • zyqwiz
        • Jun 2009
        • 333
        B0399510 Drum
        AD042059 Blade
        AD027018 Charge roller
        AD042058 Cleaning brush
        B1219645 Type 28 dev
        • YHEL23
          • Nov 2008
          • 146
          I tried once before i used Af220 drum to mp 1600le and i don't see any problem. But still better to use original parts.
          DYNAMIC OFFICE SOLUTIONS
          • rsyarcia
            Hair Straightener Tech
            • 711
            hi
            yes you can use it
            Nobody is perfect..
