repeated week areas appears in aficio 1060
  • aaahmmm
    • Aug 2009
    • 103
    Can you please help me to know what cause this repeated week areas to appears ,
    please see attached image
    Note: I made this print in a platen glass ,to be more clear
  • schooltech
    School District Tech
    • Jun 2008
    • 504
    It looks like it might have something to do with the dv assembly. Have you cleaned the doctor blade or swapped dv assemblies?
    Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
    • Scott_Lewis
      • Mar 2007
      • 519
      Hmmm......
      If this were the only symptom, I probably wouldn't do anything. I don't consider this model to be capable of sustaining this kind of printing. As long as the text and light (small) graphics are good, then that is good enough.
      The client would have to be a top 1% customer for me to 'fix' this.
      Am I being unreasonable here?
      • Brave Hart
        • Aug 2009
        • 73
        If it don’t come rite when you replaced the dev.The problem is your mag roller replace it, also make sure your doctor blade is set correctly this machine hates solids like Scott says it can’t sustain solids for a long period, and if you doctor gap is not rite you will never sustain a good solid.
        Good luck
        What? HuH?
        • zyqwiz
          • Jun 2009
          • 333
          Looks like some dev has been lost. Has it leaked out of the back bearings? If it has they you need to replace the unit.
          • mikadonovan
            • May 2008
            • 2931
            When was the last PM done and what was replaced? If in fact you think it is a leaky dev unit problem, pull out the waste toner tank and see if you have developer on top of the tank. If you do, you will soon run into misfeeding problems from the # 1 feed unit as well as the copy quality issues.
            NEVER ASSUME ANYTHING
            • tcs04
              FORMER Techie
              • 1183
              Is the centre of the Mag roller coated with hard toner? (Not Silver when wiped?) if so, scrub with dev until silver, test and change the dev if old.
