AFICIO 2045e(DSM 645) SC990 INTERMITENT
  • muaazgujjar
    • 67
    Friends, I am trying to fix an AFICIO 2045(GESTETNER DSM645) throwing SC990 intermitently.
    The case is I have serviced the machine which was stored for one year or more .Polished the drum with soft cloth and switched on the unit. After some dirty copies the unit started throwing 990.
    I have replaced the PCU as per senior techs advice but the machine is still throwing 990.
    Machine makes 13 copies in a multi copy job and it throws 990. Once the machine made 50 copies in one run but again it goes for 13.
    software ver of BICU is 2.40
    Transfer belt cleaning blade is weak .
  • Harry
    • 228
    clean id
    Dir Sir please clean Id sensor first. Then run SP 3001-2
    Set 2001-1 to default
    Set 2103-1 at 4
    Good Luck
    • Vulkor
      • Jun 2009
      • 946
      Wasn't this machine the one that required Firmware Upgrade, PM and Door Switches changed to prevent this SC?
      • Harry
        • 228
        follow mister vulkor
        mayby the id sensor get dusty while the transferbelt is not cleaning well! Try to clean out everething at first.then check the sp at my first post at least make a firmware upgrade dont ask my how i am a toshi guy but worked a couple of years with lanier also.make some ricoh now at all.i find the setup to fix this proplem in my old knowelege.It is in Italien!
        Good Luck
        • Schneida
          • Sep 2009
          • 2
          I struggled with 990 codes before, you need to replace drum and developer as a set. Then before you do developer initilazation you need to go into the laser power adjustments an set them to defaults. What happens is the power of the lasers get so high that it maxes out the memory on the machine popping the 990 codes. The laser power gets so high to compensate for drum and developer wear. After doing this the 990 codes should disappear.
          • concretefingers
            SC Code Specific
            Occurrence
            Conditions
            Cause Action
            SC990 The following data is
            stored in the SC error
            log:
            File:
            procon.c
            Line: 8xxx (ex. 8573)
            Value: 0
            Note:
            In many such
            cases, SP2103-1 to -4
            have been set to a
            value near the
            maximum (+64).
            A normal grayscale
            pattern was not detected
            15 times consecutively
            during the ID sensor
            Grayscale pattern check.
            1. Clean the ID sensor
            and/or drum.
            2. Replace the following, as
            deemed necessary:
            OPC drum
            Developer
            Cleaning blade
            Charge roller
            Charge roller cleaning
            roller
            LD unit
            3. If any of the above
            actions resolved the SC,
            perform all of the
            following:
            1. Execute SP3001-2 (ID
            Sensor Initial Setting).
            2. Return SP2001-1
            (Charge Roller Bias
            Adjustment) to its default
            value.
            3. Return SP2103-1 to -4
            (LD Power Adjustment) to
            their default values.
