Ricoh 3045
  • tcypy1961
    • 773
    Ricoh 3045
    I understand Ricoh used a different company in the manufaturing of this model and thus have problems with the operation PCB which I'm experiencing. I was told that there is a part that can be replaced that will fix this problem I believe it to be a ribbon cable??? Can anyone verify this and provide me with the part #.
    Thaks!!!
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    They are suppose to send replacement touch screens out at no charge.The number they are using cant be ordered.
    • Shadow1
      • Sep 2008
      • 1642
      There are no bulletins about bad boards or ribbon cables. Could you mean the touch panel?
      See attached bulletin
      73 DE W5SSJ
      • tcypy1961
        • 773
        That is helpful yet the copiers I service are used. I don't know if I would qualify.
        • Kopyrtek
          Copier Psychologist
          • Jan 2007
          • 407
          If you bought them second hand i dont think you can get them for no charge.But, it is only the touch screen and not the whole op panel.
