Ricoh 1045 black copy
  • bostjanma
    • Jul 2025
    Hi,
    I have totaly black copy from edge to edge in A1045! Do you have any idea why? My be laser unit? Exposure lamp is ok!
  • Jimbo1
    • Mar 2008
    • 845
    You have lost charge. Check the charge roller. Check the contacts to the charge roller and be sure they are maiking good contact. Then if that fails your HV board may be out.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • Jomama46
      • 2900
      Laser would give a blank copy except that it would code out before it made the copy. Most likely is the charge roller or the contacts on the rear of the pcu for the charge roller.
      sigpic
      A+; Network +; PDI+
