Aficio 3025 -scan to email
  • sandmanmac
    • 3981
    I have been configuring an aficio 3025 for scan to email, and it works perfectly if you set "auto specify sender"; however, if you try to set up individual senders, the emails will only sometimes reach the destination, and more often than not, they are not received. The scanner doesn't fail, it goes through the motions, and the send completes, but as I said they seldom arrive.
    I have updated all firmware to the most current, but to no avail. There doesn't appear to be any TSB's on this one either.
    Any ideas??
    Thanks in advance.
  • RicohTech_TurksCaicos
    • Aug 2008
    • 55
    Try changing the network speed from 100mbps to 10mbps on the machine
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Is the problem consistent - where the same user name always fails?
      If so, then maybe the mail server is bouncing the message based on an unauthorized sender name.
      Although that will normally result in an error at the MFP, stranger things have been known to happen when sending via email.
        • Aug 2008
        • 55
        Ken,
        But he mentioned it sometimes reaches the destination.
        • apache_cat
          I.T. Tech
          • Jul 2009
          • 81
          Not getting an error msg means it has got as far as the smtp server. If the spam filter kicks in and grabs it there will be no error msg at the copier. Spam filters depend on what they are set to look for. Some will kick in if there is no subject. Like Ken says it could be the sender you are using.
          But if you can talk to whoever maintains the spam filter you will sort it out.
          • sandmanmac
            • 3981
            Thanks for the tips guys. Right, it definitely has nothing to do with the sender, or Spam filters -it fails with all senders, but not always.
            I'll definitely try the Speed setting... but not 'till Tuesday!...Long weekend! Sweet! Thanks "ricohtech"....
            • apache_cat
              I.T. Tech
              • Jul 2009
              • 81
              When you go back make sure you press the scanned file status button after scanning. This will point you to your answer. If it says done. Your problem is not the copier. If it says waiting or error your problem is the copier.
              • sandmanmac
                • 3981
                The result always says "done"
                  • Aug 2008
                  • 55
                  You are welcome let us know how you made out.
                  • msaeger
                    • Sep 2008
                    • 333
                    So when you say the scanner completes does the memory go to 100% and it says completed in the scanned file status log ? If that is the case the problem has to be beyond the copier like a spam filter or something.
                    • sandmanmac
                      • 3981
                      I previously replied that I would try changing the speed to solve my problem but I'm not familiar with how to do it. I looked through the service manual, but I can't seem to find it. Can you please advise me?
                      Thanks again.
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        Just for a test, try using a different email provider.
                        If the MFP has access to the Internet (gateway, DNS, etc, are all correct). set up an account for yourself at GMX.com.
                        It's free and uses the standard port 25. You will need to enter the username and password you used to create the account in order to authenticate.
                        Try that a bunch of times. If it works reliably, then the MFP and a bunch of other things (including network speed) are all good, and it would be time to seriously investigate the SMTP server you are now using.
                        You may also wish to check and make sure that you aren't having any file size problems, as well.
                          • Aug 2008
                          • 55
                          Thanks again.
                          user tools/ system settings/ interface you should see a section where it says ethernet speed auto with options to change it to 10mbps
                          * It is mentioned briefly in the network section pdf of the user manual which can be found on the main ricoh website link to download user manual for the 3025
