MP 2550: Privileges on the printer
  • hmac
    • Aug 2009
    • 129
    Hello,
    I have 10 computer installed in a school. The director wants to count the number of copies printed by each class. I want to install driver RPCS but this last only goes counted the number of copies by computers.
    Each class has a session on the 10 computers. I want to install several times the same driver on a computer, with a different code each time. How to make so that a session can use that a driver and not the others.
    Thanks you.
    Bye
    _________________
    HMac.
    _________________
  • Ricoh-ono
    • 339
    Instead of using RPCS use PCL 5/6. There is a utility from Ricoh that will create a pop-up window to enter a user code. This would eliminate the need for multiple drivers.
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
    • hmac
      • Aug 2009
      • 129
      Which is the name of the utility ricoh? And where can I download it ?
      _________________
      HMac.
      _________________
      • Eric1968
        • 2458
        You can add usercodes in the adress book of the machine. You can print a report which lists the copies made by each user.
        • Ricoh-ono
          • 339
          PCL 32Bit Editor. Available on the TSRC website. For those of you across the pond it is probably on TESSA.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3945
            Either TESSA or TRTM.
            • hmac
              • Aug 2009
              • 129
              I haven't found the utility in TESSA Website ! I am on Tessa Website : Technical support, where is the utility ? could you give me exactly the step to do before reaching the utility please.
              _________________
              HMac.
              _________________
              • Shadow1
                • Sep 2008
                • 1642
                Ricoh is really stingy with this - posession of this utility by anyone other than a qualified Ricoh technician will cause your copier to explode, and radioactive green worms will eat your brain.
                You might think they would post it on the website right next to the drivers. Anything that makes life easier for the customer is good for Ricoh, right??
                Appearantly they think they would loose too much money selling PrintDirector (biggest pain in the a$$ application I've ever had to deal with) And they've also just released a User Account Limits package. I don't have any details on that, but at least they announced it to us - None of the Ricoh Direct techs I've talked to know anything about the driver editor.
                73 DE W5SSJ
                • hmac
                  • Aug 2009
                  • 129
                  _________________
                  HMac.
                  _________________
