mpc2050 jamming
  • slot
    • Jul 2008
    • 341
    mpc2050 jamming
    i have a mpc2050 brand new and it jams from tray 2 only intermitantly i have changed all the parts in the bulletin and the cluches on both trays and the brackets and the lower side door and the entirer d/plex side of the copier the code in the smc is 17 i have also changed the firmware and screwed the side fence in place im now going nuts any ideas please
  • TonerMunkeh
    Professional Moron
    • 3865
    Where are the jams logged on the SMC? I saw one of these the other day where the feed tyre had run off the notch on the shaft, it is possible it might be doing that.
    Hit it.
    • KopyKat
      Nurse Ratched of Repair
      • Nov 2008
      • 366
      the goose guide for Jam code 17 says 'Replace Relay roller spring clutch (D0391166)'
      that being said...I had one where I had to change the sp for the for the tray lift motor reverse. I don't remember the sp off the top of my head. But the bottom line is that when the tray lifts it actuates a sensor and the reverses slightly to lower the paper a bit depending on thin or regular paper. By playing with the amount of reverse to back the paper away less I was able to make it work.
      take tray one out and watch how the lift/reverse works. You'll see what I mean.
      Let me add that mine was an intermittent non-feed.
      sigpic
      Relax! This firmware injection won't hurt...but it will take 45 minutes.
      • slot
        • Jul 2008
        • 341
        thanks for the info guys the jam on the smc is code 17 (relay/transport) i have changed all the slip/relay clutch on both feed units as per the bulletin and the brackets that can get bent i will look into the lift pressure idea thanks for your input again
        • daveyball
          • May 2009
          • 314
          Slot
          I found another plate not described in the bulletin, which was bent, I like you had changed all clutches etc. The plate is specific tray 2 path, and I think it got damaged when lifting in to the van on install, it sits very low, almost below the level of the bottom of the machine. The part no is D0392791 see page UO11 of the parts manual.
          • slot
            • Jul 2008
            • 341
            many thanks i will look into the guide
            • Kopyrtek
              Copier Psychologist
              • Jan 2007
              • 407
              Check what KopyKat wrote.There is a entry in the hot topics on the Ricoh site.Even gives you info on which way to change the sp mode.Dont remember what month it was on but i do remember reading it.
              • Fearless V K
                • 620
                Used to have to mess with lift motor reverse time with the older xx22/27 series all the time also.
                Don't take that toner with me!
                • Kopyrtek
                  Copier Psychologist
                  • Jan 2007
                  • 407
                  At least they gave us some wiggle room with those models.Has been a big help.Yes,the 22/27 models needed some tweaking Fearless, as do these.
                  • zyqwiz
                    • Jun 2009
                    • 333
                    I've never changed this setting - the tray lift coupling is probably cracked if you need to change it.
                    • largo
                      • 30
                      these machines have indeed a problem with jamming
                      tray 1 ON
                      tray 2 ON
                      and indeed there is an RTB from it described in the pdf above.
                      I always replace D0391164 2 times
                      and D0391166 4 times
                      this is for 2 trays
                      but my question is when i look close to the old ones there is no difference with the new ones ( i can't see any defect!) on these spring roller clutches
                      I'm self asking me the question why RICOH JAPAN use such a complicate system (and hard to replace) when you looking at the other models like AF2027 with a magnetic clutch witch are working good and simple system and replace
                      yep i know the anwser= evolution
                      but spring roller clutch was used in the old FT series on a model wit R/V
                      so no new thing here
                      greetzz to all
                      greetz
                      • E Winter
                        The former seriers had occasional issues with the paper feed process as well. I've changed a lot of these paper lift-up springs. I can't say that I have more issues with the new machines.
                        The MPC2050 doesn't like if the paper sits too tight in the cassette. In this case the spring under the bottom plate is not strong enough to lift the paper up to the feed roller properly.
                        Maybe I'm confused but I think this machine has no tray lift motor (at least for tray 1 & 2).
