clp240-d
  • kwazimoto
    • Jan 2007
    • 199
    clp240-d
    getting a SC819 616C when I install a SD card to upgrade firm ware...Yes in slot 3..
    down loaded firm warefrom ricoh /savin site .. made folder titled romdata ,made folder in side that one for G133 and my downloaded file in there..nothing else on the SD card.. Yes not trained on machine never have done firm ware on ricoh before.. only canon..any help would be nices
  • msaeger
    • Sep 2008
    • 333
    Are you trying to update it to fix the SC819 or for some other reason ?
    SC819 says bad ram, bad controller, or software error.
    You can try just putting the files into the romdata folder and skip the sub folder. I always used to do them all that way but I have found some now that only work if you use the sub folder.
    Maybe bad sd card. Make sure it is less than 2gb try the smallest one you can find.
    You are unzipping the files and just putting the .fwu files in there right
    You can try updating via the web interface and rule out the sd card part. If you wanna try that you need to get the remote files (RFU version) .
    • kwazimoto
      • Jan 2007
      • 199
      I am getting the code when trying to upgrade firm ware machine works fine... doing that because when doing booklet finishing on this machine some of the prints come out upside down.. was told to up grade had to be 1.08 or higher but it is at that any other ideas??
      • kwazimoto
        • Jan 2007
        • 199
        yes to the unzip files that was done...
        • msaeger
          • Sep 2008
          • 333
          Did you try this stuff ?
          • kwazimoto
            • Jan 2007
            • 199
            Thanks for your help used a 32M card and everything worked out great.. must be something to size...LOL
            Again Thanks
            • Scott_Lewis
              • Mar 2007
              • 518
              There are issues with using newer SD cards......
              I've found 1gb or smaller, version 1 or at least not a version 2 or SDHC type will work in all models. Anything over 1Gb uses a different addressing scheme than the smaller (and older) cards. The SDHC (version 2) cards again have another addressing scheme.
