Headed back out to this one for a 2nd time. First time around I swapped the shift sensor even though the old one showed up as good in tech mode when flagged and unflagged. I ended up unplugging it from the wall with and when that fixed it I assumed electrical demons were the cause. Headed out with firmware and fingers crossed it's not the board.
Anyone else run across this one before?
