close right door symptom now after having a 322 and replacing the sync pcb. 322 is gone but i checked the loop with the laser and door switches and they all check ok. ideas appreciated. thanks t
mp 3030
If you checked the 3 switches out of the machine that could be the problem. Sometimes the metal actuators for the switches will not depress them far enough causing the false message. You could also be running into dirty contacts. I would first check the actuator and then if that did not resolve it then replace the switches.Comment
