I would like to ask if anyone from you' know how to convert the language of Aficio 1035 - Aficio 1045 into english? my machine only have french and other european language. How do you update the firmware language? (If there is....) Do i need to download some programs or maybe reprogram something on the machine? Are there websites which you think can help me on this matter? Thank you very much.
Need Help On Aficio 1045 Language Conversion
Hi Sir, thank you very much for the reply, actually i'm a copier technician also but not really that expert.Maybe sir you can help me on this. i think i have the memory flash card and maybe i can download the memory explorer but where can i get the langauge firmware? thank you again for your help.
I only have Dutch language, which isn't a good idea, I think. Maybe someone else has the English language. The firmware is a *.BIN file which you should copy on the Flash Card. Then place the card into the machine (remove left rear cover). Place the card and switch on the machine. After a few moments the machine displays the recent firmware and the one on the card. Select which language you want to replace, and press update.
After the update switch off the machine and remove the card. Choose the new language in User ToolsComment
me again! By the way sir, i also have some machines (Aficio 1045) that are in english version. Is it possible that i could copy that firmware? Also i would like to ask if is it advisable to remove the ram on the mainboard? Someone advise me that maybe i should try replacing the ram but i never did it because maybe it's too risky. Thanks again.
E Winter
The language firmware file does usually contain all languages but you can only copy two of them into the machine. I think the most easy way is to ask another ricoh dealer in your area if he would borrow you an already prepared PCMCIA card because it may be complicated to purchase the memory card explorer software and even more complicated to get it running. This software is a pure mess and won't work with all mainboard chipsets and PCMCIA adapters.Comment
3235/45
- Turn off the main switch, remove the flash memory card cover. Insert the flash card with printed B side facing the front of the machine, Turn on the machine, press the Yes key.
Program Upload from BICU to Flash Card. Follow the procedure above except, hold down the OPERATION Switch when turning the Main power switch on. Press YessigpicWe can all Win, but at the end we all loose. Save the greyhoundComment
E Winter
Yeah I can recall that SP but I think that's only the engine FW you can rip out of the machine - not very useful if you are looking for other FW files.Comment
E Winter
