Password ricoh 2075
  • PinevskiS
    • Jul 2009
    • 283
    Password ricoh 2075
    Hi.
    I forgot a login password on ricoh 2075. How can i login like a administrator and reset a password
  • Eric1968
    • 2458
    Login as supervisor (no password). Then you can reset the admin password. If that fails, then it's time for a new NVRAM.
    • PinevskiS
      • Jul 2009
      • 283
      Ok i check tomorrow
      thanks
      • PinevskiS
        • Jul 2009
        • 283
        I can login like a supervisor but I can't reset the password and I can't change IP address.Somebody has solution
        • paperclipsandbubblegum
          • Sep 2009
          • 29
          SP5801-011 NCS clear
          • msaeger
            • Sep 2008
            • 333
            You need to log in as supervisor then change the admin password. The only thing you can do logged in as supervisor is change the admin password. After you change it you need to log out then log back in as admin. Then turn all that crap off !!!!!
