Ricoh Afficio 1232c Calibration problem
  • tanya
    • Aug 2025
    Hi,
    I have a Ricoh 1232 C and I can't get it to perform a complete calibration. When it does it gives each color but you can see they are not being laid down on top of one another-they are staggared about a half inch. I was told it could be a sensor issue.
    Please Help!
    Tanya
  • Jomama46
    • 2900
    Are you talking about ACC calibration? or do you have the model wrong.
    sigpic
    A+; Network +; PDI+
    • Copierdocisleofman
      Senior Technician
      • Aug 2009
      • 86
      Check the transfer belt mark sensor and also check that the actual belt mark is clean and intact.
      The belt mark sensor is situated behind the pcu unit.
      • FRIDGEMAGNET
        • Aug 2007
        • 377
        Can you show us an example of the calibration sheet?
        • tanya
          Example of calibration problem
          Do you want me to email it to you?
          Tanya
          • tanya
            Transfer belt
            Is the PCU unit one of two parts that can be pulled forward out of teh unit when the front door if the unit is opened?
            • tanya
              Calibration problem
              I am referring to the automatic calebration you can perform after selecting the maintenance button on the Richo 1232 C.
              • Jomama46
                • 2900
                Got it. Pull the PCU out and check the transfer belt mark sensor on the rear as suggested by Copierdocisleofman
                sigpic
                A+; Network +; PDI+
                • FRIDGEMAGNET
                  • Aug 2007
                  • 377
                  Tanya
                  No, just scan it in and post it here.
                    Senior Technician
                    • Aug 2009
                    • 86
                    Don't waste your time posting anything, it will be either the belt mark sensor that is dirty or the belt mark that is damaged.
                    the pcu is the part that is held in by three big screws by the way.
                    The machine either needs a new pcu or the sensor cleaning.
                    • category_five
                      • 93
                      Hi,
                      Please Help!
                      Tanya
                      Change the ID sensor board.
                      Information is intended for certified service personnel only. Your mileage may vary, see dealer for details.
                        Senior Technician
                        • Aug 2009
                        • 86
                        I would try cleaning the sensor or the belt mark before changing any sensors - have never had one of these sensors go down before usually the belt mark has been damaged.
                        • tanya
                          Richo Callibration
                          Here it is!
                          • tanya
                              Senior Technician
                              • Aug 2009
                              • 86
                              Have you tried any of the sugggestion?
                              Still looks like a belt mark problem to me.
