copier lanier 6735 password
  • m_e_s_group
    please help me to reset the password of lanier 6735 .
  • JimBeam
    • Jun 2006
    • 42
    I don't know how to reset the password, but I can tell you how to bypass it so that you can use the machine!
    Hold the 0 & 8 keys down while turning on power. Press 7, press START. There should be a 1 in the display. Change it to 0. Press interrupt to enter the new value. Press 0 & 9 simultaneously to escape and lock it in. Good luck.
    Where there is no prophetic vision, the people perish.
    • m_e_s_group
      thanks for help but it does not work yet .
      i want to cancel it . not to bypass
      because i want to sell it .
      • copier cat
        PAssword for Lanier
        hi,
        The method to de activate the access mode is correctly listed. It will certainly work. Unless you have not pressed the interrupt to save the change of value from 1 ( p/w mode ) to 0 ( no control ).
        REmember:
        step 1: to turn on the m/c with 0 & 8 keys pressed down.
        step 2: Enter the code 7 and press start
        step 3: Change value to 0 ( as in ur case it shd be in 1 )
        step 4: press interrupt ( to save the changes ).
        step 5: press Energy saver button ( to test printing 1 copy )
        step 6: all the above ok. press 0 & 9 together to exit the settings mode.
        Now, your m/c shd not prompt for p/w anymore.
        • m_e_s_group
          lanier 6735
          thank you very much .
          it works now without asking me for the password
          thank you .
