photoconductor type 320
  • MGUNGU
    • May 2008
    • 12
    can type 320 work in 1027
  • Jomama46
    • 2900
    No, 320 is for A265/267. the 1027 works in all the later machines including the B205 series
    sigpic
    A+; Network +; PDI+
    • rthonpm
      • Aug 2007
      • 2859
      The 320 is not forwards compatible, but the 1027 is backwards compatible with the A series machines so long as you remove an extra plastic pin from the front right side of the unit. With some old 5227s I've found the 1027 PCU works better and keeps the machine from puking all over itself.
      • MGUNGU
        • May 2008
        • 12
        thanks guys for the quick response.Lucky enough the type 320 wasnt dismantled yet.By the way is the B2050151 backward compatible? Can B2050151 fit into a 1027
        • rthonpm
          • Aug 2007
          • 2859
          The PCU unit for the newer machines will fit in a 1027, but the machine will not auto detect a new PCU since there is not lock on the gear like the supply item has.
