Ricoh Aficio 1232c
  • nan
    • Nov 2008
    • 30
    Ricoh Aficio 1232c
    All,
    I am monitoring the usage of all four toners, via the admin tool on the internet.
    It tells me all 4 toner cartridge are full, however I replaced a toner cartridge which was empty with another which was half full, but when I monitor this replaced toner cartridge on the internet it is showing up as FULL!
    Is there anyway I can get a correct toner cartridge setting or discover or check how much toner is left, instead of taking each cartridge out?
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Originally posted by nan
    All,
    Try the printer menu config page. If im right it should show you on there. Could be a wide range of issues on why your not getting a correct display via the admin tool but try the config page first.
    Incontinentia Buttocks
    • nan
      • Nov 2008
      • 30
      Ricoh Aficio 1232c
      Config page on the print menu does not give the toner usage information, anything else I can try?
      • banginbishop
        grumpy old git
        • Oct 2007
        • 894
        Ok - you have come on here as an end user not a tech and asking for help - which i have given and its correct so to roll your eyes (sarcastic) is not really going to help you.
        As i said if you go into user tools on the op panel and press printer features and print the config page it gives you the remaining toner like YOU asked - If you still think i'm talking out of my buttocks download a user manual from the ricoh website
        • nan
          • Nov 2008
          • 30
          Ricoh Aficio 1232c
          Ok. Attached is a config page. Any ideas where it is located? Cheers
          • banginbishop
            grumpy old git
            • Oct 2007
            • 894
            Attached copy from the ricoh user manual. As i dont have a copier in front of me the next time i see this machine i'll print a config page off and see what i get.
            • category_five
              • 93
              Your machine sounds like it's broken. Perhaps you should consider hiring a technician for help.
              Information is intended for certified service personnel only. Your mileage may vary, see dealer for details.
              • nmfaxman
                • 1702
                Roll this machine into the parking lot and charge $10.00 a hit with a baseball bat, and $50.00 for a shot with a shotgun, tie a chain to it and sell it as a boat anchor.
                Take the money you make out of this and buy a good color copier.
                Nuff said.
