Type 1027 PCU in other models
  • Star
    Ricoh Tech
    • 127
    I know that the Type 1027 PCU will work in several other models (3025/3030, etc), but I have not tried one in an MP2550\3350 as yet.
    Has anyone tried it in these models, and does it work ok?
  • Jomama46
    • 2900
    I know it uses the same developer and toner, but havent actually tried the pcu assy yet.
    sigpic
    A+; Network +; PDI+
    • daveyball
      • May 2009
      • 314
      Yes I have fitted one , and it works, fine, all i had to do was dev intialisation.
      the cost is slightly more but the time saved makes up for it.
      • Jomama46
        • 2900
        Good news.
        sigpic
        A+; Network +; PDI+
        • zyqwiz
          • Jun 2009
          • 333
          We've only ever fitted 1027 PCUs to these - who wants to take the PCU apart and make it like the crappy 18 or 20 cpm machines.
          You just have to run SP2-801 after fitting.
          • Koosie
            • Nov 2008
            • 121
            And if you replace the parts individually, the dev gears will strip and you'll have to go back and replace the PCU anyway.
            • Philtt
              • Mar 2010
              • 6
              Yes, I've put them in 2550s and 3350s regularly. I find the dev gears wear on the originals after a while , so best to replace the lot.
