scan to mail dsc424
  • cmpelser
    • Jan 2008
    • 173
    scan to mail dsc424
    Hi guys, i'm trying to setup scan to mail on this dsc424.
    i set it up all the time no problem, but only where the customers have there own mail server.
    now i'm trying to set it up to an external mail server, and the scan is not going through...
    things i've done:
    ping smtp.isdsl.net (to get the ip address)
    Am I missing something?
  • rthonpm
    • Aug 2007
    • 2854
    Try the following:
    Turn on SMTP authentication, most ISPs require this for any connection to their mail server.
    Check the ISP's support website as they may use nonstandard ports for their email, and also to confirm that you do have the right email server name. Sometimes business users will have access to a different mail server than a home customer's account will.
    See how those work for you.
    • category_five
      • 93
      Ping the mail server's IP through the MFP's network settings
      if the ping doens't connect input the default gateway into the MFP's network settings.
      if the ping does get a response call the ISP and ask what special settings you need. Probably as was pointed out above the mail server requires authentication.
      Information is intended for certified service personnel only. Your mileage may vary, see dealer for details.
      • pLatik
        • 169
