Ricoh 2045eSP
  • tcypy1961
    • 773
    Ricoh 2045eSP
    What is the purpose of SP 2912 Drum Reverse Rotation. I ask because I have a copier that after each copy when the left door is opened there would be a line of toner just below plastic frame of the PCU separtion claws. I checked the setting since this is a factory set item I don't know what the default value should be. The setting was on 8 I switched it to 0 yet it would only go to 1. After changing the setting I dont see that line of toner after copying. Good move on my part???
    Thanks!!!
  • Patish
    • Aug 2008
    • 66
    As I know Reverse Rotation is used for rids of toner that remains on cleaning blade.
