ricoh 7500
  • benresa4731
    • Aug 2025
    ricoh 7500
    ricoh 7500 with sc 672. I have removed and replaced the sd cards and got the machine to boot a couple of times, but it will not make a copy, also the document server wont work . If you can help me i would appreciate it.
  • Patish
    • Aug 2008
    • 66
    Have you checked the sc history ?
    I've had sc672 on mp9000. The copier has logged two codes but I've saw only sc672 on the screen. The second was the DF code.
    Check the inlet voltage and update FW obviously. If you can't copy the HD could cause the problem.
    • TonerMunkeh
      Professional Moron
      • 3865
      I'd go for the HDD too, especially as the doc server isn't working.
      Hit it.
