B222/B224 drum unit/dev. unit/dev. in g133
  • Urushiol
    • Sep 2009
    • 22
    b222/224 drum unit and dev units are available as parts and can be ordered individually, g133 seems to be a printer version of the b222/224 copiers. Drum/dev units are sold as one complete unit as a supply for them, and its only rated at 40k(IIRC). I have thought about trying to use copier drum/dev unit/dev in the printers and was curious if anyone else had already tried it.
    Rush-
  • slot
    • Jul 2008
    • 341
    not tried it yet its a nice idea it should work the only trouble is that you will have to fit them yourself so you can reset the pm in the user screen
    • Urushiol
      • Sep 2009
      • 22
      Bump
      • Urushiol
        • Sep 2009
        • 22
        Bump, G133 also known as c811, b222 also known as MPc3500.
        • zyqwiz
          • Jun 2009
          • 333
          I've tried the printer PCU in a copier and it doesn't work due to the chip/dev sensor on the bottom of the dev unit. It will be the same the other way round.
