Mpc-4000 false toner almost empty message over display
  • nashua
    • Sep 2009
    • 25
    Hi
    MPC-4000 from installation showing Empty Black & Magenta almost empty.After two month black fully empty and i replace that but message
    still their for both black & magenta.And the strange thing is over web image monitor page showing change PCU colour & Dev of Cyan & Yellow.
    Now m/c after every almost ten copy or print add toner message flashing
    for black toner.SP data of 3101-01 toner END/Near K toner remain is in
    negative mark ( - 607 ) and of M toner END/Near also in negative side
    ( - 56 ). SP data sheet of that page attached.Toner flowing from cartridge via pipe is normal.No blockage.
    WHAT SP SEETING WILL SOVE THIS PROBLEM.
  • Patish
    • Aug 2008
    • 66
    First of all do fw updating.
    • nashua
      • Sep 2009
      • 25
      Thanks I am really sorry i am new in line.
      How to update firmware pls guide.
      • Patish
        • Aug 2008
        • 66
        Don't apologize.
        I've never faced with that problem.
        This copier save the amount of toner on the contactless chip (every toner bottle has one). It gets the data by RF antenna. The TD sensor has the PCU counter.
        There's nothing tricky in fw updating. Just read the manual. BUT if you're end user I highly recommend call for tech.
        Hope you're using genuine toner and PCU.
        • nashua
          • Sep 2009
          • 25
          MPC - 4000 add toner message
          Thanks Patish. Its true that m/c displaying from installation black & magenta almost empty. And add toner message flashing.From WIM page
          displaying Change PCU Color and change Dev. Cyan & Yellow.
          Can i get FW from nrgcss site and can i write that over empty SD card.
          • nashua
            • Sep 2009
            • 25
            MPC 7500 & 4000 folder and e - mail copy over SD card
            Dear All, Can we upload scan to folder option folder which we created
            over bland formatted SD card and than same can we download.
            Guide me. New in service arena.Is any special kind of SD card require
            for this purpose or what.
            • TonerMunkeh
              Professional Moron
              • 3865
              nashua if you follow the steps for firmware updates in the manual you can't go wrong. Firmware has to be downloaded from TESSA- support.com.
              If you're going to do the firmware, update all of it to the latest levels.
              Hit it.
              • zyqwiz
                • Jun 2009
                • 333
                They do say almost empty for ages. Only replace them when the machine stops and says replace toner.
