Ricoh 2035/3035 Compatibility
  • tejas
    • Jun 2025
    I have never worked with a 3035/3045 before and would like to know
    if these series are similar as the 2035/2045 series and/or which is better. Example: Drum, Toner, Developer, Laser, Connectivity, etc.
    Any information appreciated.
    Thanks -Sam
  • Jomama46
    • 2900
    practically the same animal. They use the same PM kit and supplies.
    sigpic
    A+; Network +; PDI+
    • tejas
      Ok much appreciated!
      • TonerMunkeh
        Professional Moron
        • 3865
        Some of the fuser parts are different. Hot roller, thermistors and thermofuses are different between the two models because the fuser frame is different. Same dev, drum etc. Drum blade part number has been changed from 1045 up to B291 2354. Not sure if the laser units are totally the same, they may be physically the same but the part numbers are different.
        Hit it.
        • tejas
          Thank you very helpful.
