MP9000 Firmware f-up
  • Voltage
    • Jul 2008
    • 282
    Hope someone can help me!!
    I have updated the firmware on a MP9000 to
    Engine from B2345223L to D1015223C
    System/Copy from B2345541L to D1015541E
    Now my Printer options is now gone, and i am sure it takes longer to go into the Copier option in the SP modes.
    Any advise will be appreciated.
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    • pocket aces
      Ricoh Technician
      • Nov 2008
      • 72
      You have to upgrade everything on the 9000 1100 1350 listen to Imind
      • Voltage
        • Jul 2008
        • 282
        No only those 2. Downloaded all off them and are going to upgrade it tomorrow morning. I can find the BIOS firmware on TESSA. Is it necessary to upgrade that too?
        • iMind
          • Mar 2008
          • 1116
          • Voltage
            • Jul 2008
            • 282
            Where did you learn the word "boetie" You South African?
            i have seen that the LCDC takes forever. Did get a bit suspicious after 20min
            • iMind
              • Mar 2008
              • 1116
              No reply, file not found...
              • Voltage
                • Jul 2008
                • 282
                Thanks iMind. Problem solved
                Upgraded all the firmware and Bobs your auntie.
