Richo ScanRouter v2 Lite Setup Help
  • davbrew2005
    #31
    Scan Router Lite
    Thanks for all the info. I just recently took over management of several hotel properties that are still running 2000 and these posts helped a lot.
    • Winter
      #32
      Hi James, Please help me solve my issue which I have with Scan Router V2 Admin utility tool .. Here is the issue :
      I have the Scan router admin utility installed on a server A and my colleagues were able to scan the files and view them in the scanned folders. Life is all good .
      Now, I was asked to remap this scanner settings to server B (so we can make the Server B the file server).
      1. I installed the application on server B by running setup.exe and finally got it to launch.
      2. Opened the admin tool from the server menu go to set I/O device and gave the IP address of my scanner.
      3. Then in the destination table, I rightclicked to add a new user and the app crashes of a sudden .
      When I relaunch it, it displays a message that administrator is already logged on , it shows the host name (Server B) and username (my name).
      Could you help me resolve this .
      • IDSTechnical
        • Jun 2009
        • 55
        #33
        Hi There,
        I have seen this behaviour before but I'm not sure i have a resolution for you, what OS and Scanrouter version are you using?
        It is however possible to kill the process controlling the login. I will reply again tomorrow with the process name.
        • Winter
          #34
          Thanks for your reply. OS is windows 2003,SP2 and scan router version is 2.0.6.0 ..
          I'm facing a new issue. Please let me know if you can help.
          1. I have been following your steps in setting up the scan router . Since I could not add destination users, I tried to add I/O device and added the scanner IP address that was originally added on Server A. (since the printer was the same)
          Is it that scanner only sees one server at a time ? coz all the scanner folders on my printer were lost and could not find them now. But i see them on the scan router admin utility tool .
          Also, I was trying to trouble shoot issues and one of the attempt was to stop and restart scan router driver service from Administrator tools->services.
          Not sure if that had any implication, when I launch my scan router utility ,status shows as unknown. When i click resume services, it says this operation cannot be performed since the delivery scheduler has not been started. Please help how can I deal with this.
          • IDSTechnical
            • Jun 2009
            • 55
            #35
            Hi Winter,
            Just intalled on a 2003 box and I have it working OK. Do you have anything else on the server? An earlier post stated it can't be installed on a DC and I have had issues on SBS because of this. I have also had issues installing on servers with symantec antivirus installed.
            As a start point though I would delete the connection to the MFP fromthe old scanrouter box and also the new one. Then recreate the connection in the I/O dialog box so you can start a fresh.
            Let me know how you get on.
            • Winter
              #36
              Originally posted by IDSTechnical
              Hi Winter,
              Hi James,
              Awaiting your reply as this issue is a show stopper for me. Anyway thank you comming back. To start with, this server is not a DC . It does not have Symantec antivirus. System doesnt have much of softwares on it but it has a lot of data .
              Like you said, I deleted from the old scan router and added in the new one. It added fine with no issues. Next thing I tried is to resume services. The status at the left bottom displays 'service status unknown' . CLicked Server --> resume services . It shows the message 'this operation cannot be performed since the delivery services has not been started' . And then I tried to add a new destination user but the app crashed as usual. Please help.
              Winter
              • Winter
                #37
                James, Im trying to look in the scan router folder C:Programfiles\RDS if I can find any executable for delivery scheduler . I have found DdsLaunch.exe which is the exe for delivery services, double clicked but looks like nothing happened.
                Winter
                • Winter
                  #38
                  Also I could not see the undelivered data in tray option in the delivery table in new server. I had suspended services on the old one, delete the undelivered doc's in the undelivered data tray of the old one. Not sure what went wrong here.
                  • Kekersguy
                    #39
                    Re: Richo ScanRouter v2 Lite Setup Help
                    Originally posted by solorajder
                    I have a problem to connect MP171 with scanrouter.
                    When I try to connect MP 171 with scanrouter "set I/O device, add.., browse..," the machine is present on I/O list, but when I click OK, I get a message "The selected I/O device is not switched on, or is not available on this network", but MP171 is turned on and printer is working.
                    It is the same if I write IP of machine instead of browse.
                    I also connect MPC2000 with the same procedure and I don't have any problem.
                    Got any idea what could be wrong?
                    I am experiencing th same problem, did you manage to get your issue resolved, any help or pointer appreciated.
                    • sandmanmac
                      • 3979
                      #40
                      Scanrouter does not work on these newer units. No software is required.
                      Setup scan to folder via SMB/ FTP, or scan to email
                      • rthonpm
                        • Aug 2007
                        • 2848
                        #41
                        X1000 ScanRouter is a relic from the time when copiers needed middleware to communicate with a PC. Those days are long gone now and the newer MFPs are integrated machines, not just add-on cards installed in them.
                        • nivomat
                          • Mar 2015
                          • 5
                          #42
                          I installed this version of Scanrouter on my computer, but now I have this problem:
                          1) I can't enter for managing server: error message "password is invalid"
                          2) Software can't be uninstalled because you need to remove server before; but for remove server you need to insert the password (see point 1)
                          How can I insert the password or uninstall Scanrouter? The password of the user/admin of my computer is correct, but Scanrouter doesn't recognize it?
                          Is there a new software that replaces Scanrouter?
                          (My device is a Lanier LD118 and a Ricoh Aficio MP C2550)
