Savin 9021D and 8020D
  • aaronhun22
    I've been offered two savin machines by a company and I wanted to know what they're worth. They said that the 9021d is 1 year old and I don't have the age on the 8020d. If you could shed some light on what you think their worth is that would be great.
  • aaronhun22
    Anyone
    Anyone. I just want to make sure I'm getting a good deal.
    • msaeger
      • Sep 2008
      • 333
      Do they have fax, print, and scan ?
      There is one on Ebay with a buy it now of 899.99
      • aaronhun22
        Fax, print, and scan.
        I don't believe they have fax but they do have print and scan. Fax isn't really important to me.
        • Vulkor
          • Jun 2009
          • 946
          9021d introduced 1/1/2007
          8020d introduced 10/1/2005
          If they have copy print fax, yeah worth over 1k if meter is not absurd.
          IF the 9021d has the DDST Controller board then Scanning is only working Via Network TWAIN.
          If you want Scan to Email and Scan to Folder then you need the 9021 with the full fledged controller. Hopefully the seller knows the difference. You can tell by looking at the Scanner Screen.
          Both of these are low volume machines.
          • aaronhun22
            Thank you
            Thank you. That helps a lot. I will check for those things, especially the meter.
