MP161 MFP - Web image monitor
  • sandmanmac
    • 3979
    Having difficulty logging into web image monitor.
    The username seems to have been changed to "administrator" from the default "admin", and the password must have been changed too.
    I logged in under "supervisor", but changing the "administrator" password doesn't take.
    Question: should I also be able to change the username here? because the current username (administrator) cannot be changed. I do have the option to change the password, but like I said, it makes no difference when trying to login again.
    Strangely, I can change the "supervisor" password.
    I've tried SP5-801 (all clear)
    There seems to be some security setting made on the machine that I can't figure out, that may be causing this.
    Under user tools/System settings/Administrator, when I select "network security level", it says "Privileges are required to use this feature". Is there an SP to reset the security privileges that may help me here?
    Thanks in advance.
  • aabarnes1
    • Mar 2009
    • 620
    You must login as 'supervisor' with a blank password, here you can change any admin, user, file manager password. I dont want to sound smart but the full explanation is in the security reference in the manual
    Grant me the serenity to accept the things I cannot change.
    • sandmanmac
      • 3979
      Thanks, but I think you missed this line in my post:
      "I logged in under "supervisor", but changing the "administrator" password doesn't take."
      So "yes" , I am logging in that way, and the change doesn't get saved.....that's what I'm asking.
      • Vulkor
        • Jun 2009
        • 946
        If it doesn't take and you've done a MEMORY Clear. Then I'm thinking Flaky NVRAM?
        • portviking
          • Sep 2009
          • 18
          after changing the password do you press the "ok" button about 3 times? If you fail to press it the correct amount of times it will not come up and say programed. Also I believe that you can do the same via Web image monitor. It might be easier.
          • sandmanmac
            • 3979
            Thanks, but I actually solved this months ago, in fact I can't remember EXACTLY what I did, but I do seem to remember it had something to do with Authentication settings that had been changed by a previous owner or service company. Once I turned it off, all was good.
