Good Day,
I have fiery E7000 connected with CS555.(Venus 1)
The problem is printing is working fine,web scan is not working.
i have changed the fiery HDD.After changing the HDD web scan is worked for only one day.
I will able to select scanning resolution,i can able to give dest number for scanning,i will able to select mode color / B/w. But once i press the green button . the machine will hang. and after 2 min. sc997 will apear on the display.
I am expecting some advice from you all.
Regards,
Raja.
Regards,
Raja.
