How to set SFTP on Ricoh MP171 spf?
  • Gesttech
    • Oct 2009
    • 123
    Hello everybody
    can somebody, Tell me how to configure Scan to SFTP on ricoh mp171spf. I Tried but don't have solution.Help
    Thank
  • Jomama46
    • 2900
    Same as SMB only change the settings to FTP.
    sigpic
    A+; Network +; PDI+
    • Gesttech
      • Oct 2009
      • 123
      aNSWER
      Jomama46
      Thank for your reply I know how to configure FTP, But I Not sure for SFTP(SECURE FILE TRANSFER PROTOCOL), Because that I need help.
      I know it same like SMB but need to shared folder & FTP You need a ftp server. What professionel you mean?
      • Jomama46
        • 2900
        SecureFTP is not mentioned in the lit. I suppose that means its not supported?
        sigpic
        A+; Network +; PDI+
        • unisys12
          • 489
          It's been awhile, but my understanding is that the only difference between FTP & SFTP is the inclusion of a user name and password in a SFTP connection. Someone please correct me if I'm wrong...
          I've never set up a Scan to FTP connection on one of these little buggers, but i know that all our other newer models have fields for user name and password, so... I would assume this model would support it as well.
          *NOTE* Just checked, this model does support sftp connections
          Perform a search on the Global Knowledge base and you will find a lot of good info on FTP. Specifically one article Active and Passive Modes. This maybe be your problem, if you are entering the correct username and password. Perform the search on all models. Do not specify just the 171, because you will not find what your looking for.
          sigpic
          The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
          • scoobysteve
            • Jun 2008
            • 163
            hi,
            I'm pretty sure the MP171SPF have an option to input the username and password for FTP.
            I believe you can input the username and password via each individual entry in the address book or via the "File Transfer" option under the "Configuration" option in the web interface.
            Otherwise, if you go via the control panel do the following:
            User Tools/Counter
            System Settings
            File Transfer
            Default Username/Password
            FTP
            and then input the relevant details.
