AFICIO 220/1027 toner spill
  • +ve charge
    • May 2008
    • 87
    Pls let me know what causes toner to spill off the 2 sides of the transfer roller (some machines 1 side) onto the white plate under the transfer roller. This happens even after 500 copies are reproduced. picture attached.
  • Vulkor
    • Jun 2009
    • 946
    Seen machines do that for years. Maybe too much black on customers copies cause overtone add or transfer roller voltage too high. Never figured it out. It usually doesn't effect quality that I've seen.
    • ivacopy
      • Oct 2008
      • 46
      Hi
      From my opinion the problem is developer unit.
      • TonerMunkeh
        Professional Moron
        • 3865
        I've noticed this on high-mileage PCU's. Switch on transfer roller cleaning in SP2xxx something. It's at the bottom of the list somewhere.
        Hit it.
        • +ve charge
          • May 2008
          • 87
          Hi.. First started noticing this anomaly when small parts of the leading right or left edge (or both edges) of the copy paper were getting stained with toner. Once the Transfer Roller and the bottom plate are cleaned it works well for about 500 sometimes 1000 copies before it happens again. Will try the suggestion mentioned by T.M and see how it works. Thanks for response.
