Hard Drive replacement. How to initialize.
  • kayjaig
    • 144
    I have replaced the hard drive for Aficio 2075. It gave me error SC870. i believe there is way to initialize it, but don't know how. please help.
    By the way. As long as it is IDE drive, do the size matter. does a 250 GB okay to replace with the 40 GB old one? thanks.
  • E Winter
    check SP5-832
    very large HDDs may not work or needs diffferent jumper settings.
    • ivacopy
      • 46
      Check the jumpers settings on previous hard drive and set new hard drive
      • Jomama46
        • 2900
        not on 10 or 2075. Gotta have the Ricoh.
        sigpic
        A+; Network +; PDI+
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          sigpicWe can all Win, but at the end we all loose. Save the greyhound
          • Jomama46
            • 2900
            There was a bulletin about making sure the firmware is up to date on the 1075 when replacing the HD, due to a vendor change. Note this may not apply to the 2075 but always a good idea anyway.
            sigpic
            A+; Network +; PDI+
            • iMind
              • Mar 2008
              • 1116
              Yep, for some reason theres a TB.
              • redstone
                enter SP under mode try to browse for HDD initialize setting
                • teebee1234
                  • 1670
                  I believe it may be under "special service mode", which you access by holding the "#" key when pressing the copy sp button.
                  • Shadow1
                    • Sep 2008
                    • 1642
                    The replacement drive must be jumpered as master - Cable Select (which is the default for most new drives I've gotten in the past 2 years) will not work.
                    The drive should automatically initialize, but if not it's SP5-832-001 in standard service mode.
                    73 DE W5SSJ
