you would think its the strip glass but its clean. not getting this 3 inches of streak when i place the original on the glass only when the documnet feeder is being use. cleaned al the mirrors and glass and no luck. i had this issue before where the scanned unit was not set properly ive tried adjusted the scanner unit with no luck.
something like his seems realy daft. i need to gt to the bottom of this.
also cleaned th white strip that you find next to the slip glass.
