Ricoh FT-3213 E-52 lite
  • Jedisezhi
    I have a Ricoh FT-3213 that is giving a E-52 lite. WhAT IS INVOLVED IN REPAIRING?
    Thanks Jed
  • sandmanmac
    • 3983
    Sorry Jed....
    But more than it's worth. it's a fuser error...Likely a fuse or lamp, but whatever it is, it needs to be replaced,(and parts are pretty scarce for it now), then the code needs to be reset in service mode, which involves setting dip switches on the motherboard, etc...etc. which i'm not about to get into here...bottom Line is, I wouldn't spend $50 bucks repairing that machine at this point -it's 15 years old, and can be replaced for a few hundred bucks with an entry level all-in-one these days.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
      from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        Old school, hehehe, Try this if it works great:
        on the +,- button take it to 71 then press clear mode for more than 5 seconds then a little dot ( . ) on the bottom of your two digit display will light-up then press clear mode again and then press interrupt a (5) will start blinking that means your in service mode: then just turn off the main switch and back on if there are no defective parts the machine will start warm-up.
