aficio 2075 copy problem.!!
  • master1
    • Nov 2008
    • 16
    hi
    my printer and copy machine has a problem
    In addition ..
    As you see
    If you do help me very happy
    Thanks..
    Imageshack - 20091027172509898
  • aabarnes1
    • Mar 2009
    • 620
    This looks like your laser unit my friend. Do you have a spare you can swap to eliminate the laser?
    Grant me the serenity to accept the things I cannot change.
    • iMind
      Vacuum Cleaning Expert
      • Mar 2008
      • 1116
      looks like fuser imaging.
      • teebee1234
        • Jul 2008
        • 1670
        I've seen this before. Those are digital artifacts (not fuser related). I can't remember if it was laser or board. I'll try and confirm tomorrow and check back if you haven't resolved it by then.
        • pocket aces
          Ricoh Technician
          • Nov 2008
          • 72
          could be the hard drive
          • _Brent_
            • Jul 2009
            • 39
            That looks like a drum drive unit problem. I would check all the belts, pulleys, gears and motor that are associated with drum drive, back side of the printer. It seems like the drum is slipping.
            • Frank12
              • Nov 2008
              • 77
              Originally posted by master1
              hi
              In addition ..
              As you see
              Thanks..
              replace sbu board , goodluck
              • master1
                • Nov 2008
                • 16
                thanks
                I'm trying .. results will tell
                • CableGuy
                  Impulse Drive Engineer
                  • Oct 2008
                  • 417
                  LD unit
                  Hi.
                  I've had to replace a few LD units on these machines.... Looking at your sample, it looks pretty similar to what I was having.
