Savin 9021D Product Code B277
  • mansart
    • 855
    Can anyone tell me what I need to make this a printer. Customer bought as a stand alone copier, now they want to print, what is product number?
  • teebee1234
    • 1670
    Printer/Scanner Unit Type 2000 kit - Product code is B867 (EDP code 413572)
    • mansart
      • 855
      Thanks TeeBee
      Thanks for the info, regarding the Ricoh print board. I can buy a Ricoh All in One Kit Type 2000 (Scanner Printer Fax) for $299, is that a fair price? Also is this all I need to make machine print? Is this an easy install? Yes I am a tech, mostly Sharp however trying to help someone out.
      • teebee1234
        • 1670
        That's dirt cheap. I know retail is probably close to $2k (at least originally). You'll need documentation to install it (it comes in the box if it's all original). If not, I can email you the pdf. The kit is all inclusive - controller box, op panel, dummy covers, SD card, ram dimm, hardware. Nothing hard about installation if you follow it step by step.
