mp 4000 bridge unit
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    mp 4000 bridge unit
    Ok, silly question but is anyone having problems with the bridge units on these. I've had 2 both with under 6k on the clock and dog ears the copies on duplex mode going into the bridge unit causing it to skew in the finisher entrance.
    I've watched one do it and i saw it hit the bridge unit guide for internal exit or for the finisher exit(front side). I adjusted the guide height but it still done it. It now looks like it has rectified itself but i was called out yesterday for the same problem on a different m/c with 6k on it - tested it but it was fine but the jam log said entrance sensor of the finisher i.e. its skewing the copies.
    Incontinentia Buttocks
  • Smee
    • Aug 2009
    • 178
    Im not too sure about this model, but in the past with the mpc range ive had problems with people not installing the 2 brackets onto the thin black exit rollers just before it enters the bridge unit - this always causes dog ears.
    The 2 brackets come with the bridge unit kit and are not used on machines with the wide white exit rollers - only on the thin black exit rollers.
    • Frank12
      • Nov 2008
      • 77
      check the alignment of mylar guide at the exit bridge unit, or check the two roller spring at buttom of mylar guide
      • Koosie
        • Nov 2008
        • 121
        Agree with Smee. I've also had that on the MP4000's. Always read installation instructions when attaching peripherals!
        Part no for guides: 2 x D386 4674
        • banginbishop
          grumpy old git
          • Oct 2007
          • 894
          ok, where does the D386 4674 sit then. I've looked at the bu3030 parts manual and it doesn't give me an idea where it goes.
          cheers
          • Lagonda
            • Aug 2008
            • 1649
            I'm fighting this one at the moment, using a better grade of paper helps. The low grade sand paper the customer was using had a definate curl to it, ran a couple of reams of our paper through and it didnt jam once.
            • gladin
              I have had this same issue and from what I observed It was dog earing the corners on the way into the bridge unit on duplex only because of excess paper curl. The cure was to file down the two entrance guides on the entrance of the bridge unit. There are two guides that are raisied higher that the corner of the paper was catching on.
              • Lagonda
                • Aug 2008
                • 1649
                Eureka! I've just checked the offending copier and the two guides,D386 4674, are missing! If you want to know where they go Bangin Bishop, check the bridge unit installation guide in the MP4000 sevice manual.
                This is our showroom copier that has been reconfigured several times to go out to prospective customer on demo. obviously the bridge unit has been swapped but some one missed the guides.
                Thanks for the tip Smee and Koosie, I could have been there for ever looking for something that wasn't there!
                • banginbishop
                  grumpy old git
                  • Oct 2007
                  • 894
                  which part of the guide are you moding then?
                  • banginbishop
                    grumpy old git
                    • Oct 2007
                    • 894
                    I'll look in the morning on the ricoh website but thanks for the reply and i'll post back on this.
                    • gladin
                      On page two of the parts manual I am filing down the two outer ramps of the main body as shown below number 21 and 23. When I removed the cover (one screw on side of the machine) I was able to observe the paper exiting the main body curling and catching on the raised outer ramps. I hope this helps.
                      • msaeger
                        • Sep 2008
                        • 333
                        I have fixed this by dropping the fuser temp 20 degrees. It hasn't caused any other issues like poor fusing. The hotline just gave the standard cop out "they need better paper".
                        • gladin
                          On page two of the parts manual you will see the main body, there are about 16 ramps that guide the paper. The outer two are raised higher. If you remove the cover below the scanner and to the right of the bridge unit (one screw on the side of the machine) you can watch the paper as it enters the bridge unit. On the two machines I had this problem with I could see the paper catching on these two raised ramps. These ramps are located below numbers 21 and 23 in the diagram. I hope this helps.
                          • Smee
                            • Aug 2009
                            • 178
                            I fitted 2 this morning - they go on the 2 exit rollers on the copier itself, not the bridge unit. Make sure you fit them round the right way - they just clip in place.
                            • banginbishop
                              grumpy old git
                              • Oct 2007
                              • 894
                              smee, is it fitting on section 39 of the mp 4000 parts diagram? If not, can you post a picture please as i'm getting confused a bit. I've looked at the service manual on tessa but its either in italian or german only?
                              cheers
