Pro 1357 Ex Parper Jams
  • CableGuy
    Impulse Drive Engineer
    • Oct 2008
    • 417
    Hi All
    Quick question. Is anyone having an above average paper jam problem on tray one on this model. I have to date replaced the feed tyres, then when the fault returned, I swapped over Tray one and Tray two feed units, putting the new feed tyres in tray one. The problem has resurfaced again on tray one. One of the symtoms is that it seems to snag on the seperation roller causing a small indentation on the leading edge.
    Any toughs would be appreciated
    Thanks in advance
  • Sashko
    • Oct 2009
    • 110
    Originally posted by CableGuy
    Hi All
    Thanks in advance
    Hi,
    Yes, you are right. Problem is in the separation mechanism.
    I had same problem on Pro1356ex, paper didn't feed from tandem tray.
    I exchanged the paper feed unit between the tandem tray and the lower tray.
    Problem migrated with the paper feed unit.
    I my case, problem was solved when I disconnected and reconnected again all connections inside the paper feed unit. Especially for solenoid.
    I think this helps you.
    Sashko
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      i have heard from other engineers on here and at work that the torque limiters are causing problems on these machines.
      Incontinentia Buttocks
      • CableGuy
        • Oct 2008
        • 417
        That reminds me, I have replaced the torque limiter too.....
        • banginbishop
          grumpy old git
          • Oct 2007
          • 894
          yep i found that out when i done a search after i posted. Is the sep shaft nice and clean. I found on ricoh doc feeders(sep shaft) the shaft had to be clean and free from any imperfections, dirt etc. I normally rub wet and dry to take the crap off it. Havent had a chance to look at the parts manual so i can only really guess.
          Hows tray 2 doing now you changed that from tray 1, is that still doing the same fault?
          • imaginemoko
            unTrusted Tech
            • Jan 2008
            • 289
            as they mention Torque Limiter Replacement, mostly if its new from factory they tend to be faulty...
            fix the customer first then fix the machine... its simple and makes life more easy.
            • CableGuy
              • Oct 2008
              • 417
              Tray 2 is running A4R, But I have my suspicions that it would play up if I turned it to A4.....
              I worked on this machine today, had to do a PCU PM and Transfer unit. I did nothing other than fan the paper and check nothing was out of place in the right-hand tray. And whilst I'm at it, it loads paper just fine from the left tray. I had my first and only jam after 2500 copies and when I left it had done about 7000 of the job it was busy with, no further problems. But I don't trust it as far as I can throw it!! I was wondering if the paper isn't high enough when it is raise towards the feed rollers.....
              I don't think this is the end of my problems, only because I haven't actually done anything, although it is working at the moment.
              Thanks for your ideas guys, I'll keep them in mind when I see the machine again, which I have no doubt will be in the near future.
              Cheers
              • PinevskiS
                • Jul 2009
                • 283
                HI
                I have this problem whit mp pro 1356ex and I find the problem.you must print SMC report.See in SC histori if there have a SC 670 you have a problem whit power current machine don't work on 220W.I change feed roller's ,clean all sensors and change a small bearing on feed stations and nothing.Check in SMC this code
                • CableGuy
                  • Oct 2008
                  • 417
                  Originally posted by PinevskiS
                  HI
                  Hi,
                  No SC670's on the log. But a good thought though. Spoke to the customer this morning and the machine is still running, for now. Still think it is only a matter of time though. You always worry when a machine starts working without having done anything to get it going.
                  Cheers
                  • CableGuy
                    • Oct 2008
                    • 417
                    Hi all
                    As expected, the problem returned with a vengence. We have also established that the customer is using 75gsm paper, but this is well within the spec of the machine. Finally escalated the problem. Ricoh came out had a look and have escalated it to Ricoh Europe. So I'm guessing there must be something wrong.
                    I have in the meantime found out that other people have been having this problem and that the Torque limiters have been modified at least twice, although the part number may not have changed.
                    So it looks like here may be an underlying problem with these feed units, I'll let you know what transpires from this
