MP 3350-SC 819
  • armas
    • Aug 2025
    MP 3350-SC 819
    Hello friends,please help! I have MP 3350,after switching on it will show a message "Please Wait'' then it will give SC 819. I can not open also simulation 107.What shall i do, Please help. Thank You in advance.
  • rthonpm
    • Aug 2007
    • 2859
    Sounds like there's a memory DIMM that's gone bad or loose. Try re-seating all the memory DIMMs then re-flash the firmware. If that doesn't do the trick then try replacing the memory.
    • TonerMunkeh
      Professional Moron
      • 3865
      That's the controller board, I've had 3 do it. Replace it and you'll be fine.
      Hit it.
      • armas
        friends,thank you for your quick reply,i will try to replace the contoller board.
        • armas
          TonerMunkeh, can you tell me the right part number of controller board for this model MP 3350B.Thank you again.
          • TonerMunkeh
            Professional Moron
            • 3865
            D019 5310 for the monochrome scanner, D020 5310 for the colour.
            Hit it.
            • armas
              TonerMunkeh, thank you for always there!
              • Oluwadare
                • 28
                NAND Flash Memory
                must the controller be replaced? Is it not possible that someone know how to reset the
                NAND Flash Memory on the controller board which is the cause of the problem?
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Yes, the controller MUST be replaced.
                  Hit it.
                  • rza1013
                    Re: MP 3350-SC 819
                    update firmware, if that doesnt help replace hard drive
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      Re: MP 3350-SC 819
                      Some 3350's don't come with hard disks. Updating the firmware won't cure the fault as the board failure makes the machine unresponsive to dip switch 1 being enabled, it will just code with SC672.
                      Hit it.
