MPC 2500 touch screen problems
  • bostjanma
    • Jun 2025
    Hi,
    I have problem with precisely fix the icon on touch screen. First I made calibrate with no result. Sometimes the problem lose with power switch off/on. Before I order new touch panel I need your advice if anything other wrong.
    Thanx
  • ss12
    • Jul 2008
    • 289
    ricoh tech bulletin RB230058 replacement touch panel fix
    • Hero Geo
      You have to replace touch screen. They are very cheap as this is an ongoing problem.
      • bostjanma
        I solved problem with replacement touch panel. Yes, it is not expencive and display works.
        Thank you all
