Problem on fusing unit MPC 2800
  • sebreizh
    • Oct 2009
    • 28
    I have a problem with the lamp melting of MPC 2800. This is my third machine in 1 month.
    The dual lamp is hs. Someone knows this problem?
    Reference lamp
    AX440275 213V 460/640W.
    Thank you for your reply
  • StormyKnight
    • Dec 2008
    • 50
    Would you believe there is an actual firmware update to fix this issue? We had a bulletin recently & it was a firmware update required, it must somehow reduce the stress on the lamp....
    • sebreizh
      • Oct 2009
      • 28
      This is simply an updated firmware?
      • E Winter
        Not really - ricoh does currently recommend to lower the auto-off timer value. The final fix is an improved lamp.
        • sebreizh
          • Oct 2009
          • 28
          I read on the site that would be a problem of gas in the lamp and that Ricoh would try to make another. Is anyone aware? Ricoh should know this.
