What would cause the wrench light to appear on your display for the paper trays? It started out in the last tray and has since moved up to all trays except the bypass tray. Does anyone know what can cause this? Any help appreciated, thank you.
Ricoh Aficio 350e
incorectly loaded paper, bent tray guides and paper behind the cassette and the motors are old, whats codes you getting?
look at the motors -
Likely a bad lift motor, You can pull a tray out and listen to hear if its was raised up. Also you can remove an upper tray to watch the tray below.
What was the code?sigpic
A+; Network +; PDI+Comment
Thanks!!!Comment
The problem was a blown 4 amp fuse on the power source PCB. The problem started in the lower deck (last pf drawer(wasn't explained well)). My question would now be is this a short in the lift motor in lower deck??? Customer said the copier had a burning smell.
Thanks!!!DYNAMIC OFFICE SOLUTIONSComment
