MP1350 Skip Feeding
  • Shadow1
    • Sep 2008
    • 1642
    MP1350 Skip Feeding
    I have a customer with 2 MP1350's. They have been running side by side for millions of clicks, and they have always performed about the same.
    I did a service call on one for folded corners (buildup on a stripper finger) and noticed it wasn't feeding consistently. The machine next to it is running the exact same job and feeding fine.
    The machine will feed maybe 10 or maybe 100 sheets then randomly pause for 1 feed and pick back up like nothing ever happened.
    The stock is fairly common 80gsm and the job is duplex, so I don't think its a low heat problem in the fuser. One of the trays this job was using had over 600k on the feed rollers, but it didn't make any difference when I replaced it.
    The only thing I can note between the machines is a slight difference in firmware. The "Good" machine is System ver 3.12 and Engine 3.22.1:16 and the "Bad" Machine is 3.10.1 and 3.20.2:16. As I said, these machines have been running side by side like this for years, so I guess its possible it's always skip fed like this and we just haven't noticed it, but it really stood out to me as I brought it back online, and I really doubt we would not have noticed it before.
    Anybody got any ideas? I really hate to upgrade the firmware because both machines are still running B234 and I'd have to go to D101 - I'd hate to see one of them fail...
    73 DE W5SSJ
  • Eric1968
    • 2458
    Are the printed pages copies or printouts? Have an SP8200DN printer which does exactly the same. No errors, SC-codes, but sometimes a pause in the print process.
    • Shadow1
      • Sep 2008
      • 1642
      Prints - in over 10M prints there are less than 1000 copies on these machines, and most of that I think was me testing.
      Same scenario - no SC's, no Jams, just a quick hiccup every once in a while.
      The main operator on this machine agrees with me - if it had been doing this for any length of time, we'd have noticed it.
      odd.
      73 DE W5SSJ
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        just a thought, maybe drum is over life and it pauses for process control adjustments.
        • iMind
          • Mar 2008
          • 1116
          I can send you the 3.12 and 3.22 firmware
          • TonerMunkeh
            Professional Moron
            • 3865
            I'd go with something to do with process control to. Not being trained on the Katana I can't really comment, but how often do they run process control?
            Hit it.
            • Voltage
              • Jul 2008
              • 282
              It doesn't have anything to do with the double-feed detection sensor being dirty?, just a guess.
              • Shadow1
                • Sep 2008
                • 1642
                Lots of good suggestions, but...
                The drum is less than half its PM - I guess it could fail early, but if memory serves, the machine only develops an ID sensor patch every 10 copies. I would expect the pauses to be at somewhat regular intervals - we've observed it skipping very rarely after as few as 3 and sometimes after hundreds.
                ID sensor has been cleaned and the process area was fairly clean.
                Double Feed Detect is disabled on the machines.
                I don't know that it will help, but I'd appreciate the firmware (.rfu if you have it - my SD card got borrowed and is still AWOL) I'll PM you my email.
                I thought about formatting the drives, and I've also got a set of used HDD's I wiped. I would expect errors if they were failing, but I've seen drives get slow for a while before they die.
                73 DE W5SSJ
                • tcs04
                  FORMER Techie
                  • 1183
                  I don't know why it would pause after 3 copies, but check SP2507. If turned on (001) the machine will produce an I.D patch at the interval set in "002". normally used to hold image density on high coverage jobs.
                  This SP is the best way to retone a machine with low density, much better than forced toner supply. It can be set to 10 copies and as long as all functions are working the machine will retone without killing the dev. Also available on other models.
                  • Shadow1
                    • Sep 2008
                    • 1642
                    I Installed the same firmware as the "good" machine (Thanks to iMind) and no change.
                    The machine started throwing SC300's, so I put in new charge assemblies (didn't even make it to 500k this time) Still no change
                    No better, No worse. Its annoying but not critical, so I may just have to wait until it decides to give me annother clue.
                    Any further ideas would be great...
                    73 DE W5SSJ
                    • paulg
                      • Jun 2007
                      • 278
                      IS the Drum Earth good seen that make Katanas and bellinis do some weird things and of course the old favourite trapped wires. HDD and Memory are also have a tendency to make the weird actions possible.
                      I take it all the Filters and airways are good and the fusing lamps are all a ok?
                      • Shadow1
                        • Sep 2008
                        • 1642
                        Drum ground is good, but I haven't put my meter to the lamps yet - good Idea.
                        Customer reported a new symptom (possibly) the machine stopped in the middle of a run for about 4 minutes. No errors, still said copying, and picked up again like before. This may have been a normal ProCon cycle, but who knows.
                        They're in the middle of a huge run right now, so they don't want to take it down unless it gets bad - Now over 24 hours it's about 2 hours behind the other machine due to the "hiccups."
                        When they get done this run, I'll Ohm out the lamps and toss in a pair of HDD's - anybody remember what type? I think it was 160G or better SATA, but not sure, and I'd like to make sure to bring in the right ones.
                        73 DE W5SSJ
                        • Voltage
                          • Jul 2008
                          • 282
                          Have you changed the complete charge unit. Maybe its arcing. Just a guess.
                          Maybe swap it with the other machine's
                          • Shadow1
                            • Sep 2008
                            • 1642
                            Yeah - I've learned when I get an SC300 its not worth trying to rebuild the corona and maybe get 10k out of it. I keep 2 sets on the shelf for the customer, so I just swapped it out.
                            They've put 250k on both machines in the last week with this big job, so a PM will be in order by the time they are done. That'll make sure its nothing process related unless there's a bad sensor, and I don't see anything like that now. I can check the fuser lamps at the same time, and if everything checks out I'll put HDDs in it and go from there.
                            73 DE W5SSJ
                            • Shadow1
                              • Sep 2008
                              • 1642
                              New Info:
                              The customer is still running their huge job, and the machine is about due for a good PM, but CQ is still good and they don't want to stop production. I did have to swap out Corona's because of SC300's, and I put my meter across all the heat lamps while I was there. Also reformatted the HDD's
                              So, good charge, clean drives, good heat lamps (AC driver board could be bad I guess - didn't check to see if the lamps were actually lit, which I'll do at PM) and firmware matches the machine that is running normally.
                              Still looking for more Ideas.
                              73 DE W5SSJ
