ricoh3035
  • hodgiepodgie
    • Jul 2008
    • 284
    ricoh3035
    getting fax error 14-01.also saying trnsfrg file to folder.faxes not printing out.what is the issue here?
  • Sashko
    • Oct 2009
    • 110
    you must check all network setting (IP address, DNS, SMTP etc), LAN cable, shared folder and user rights for it.
    • hodgiepodgie
      • Jul 2008
      • 284
      ok
      what is the code14-01.thnks
      • Sashko
        • Oct 2009
        • 110
        Message: Check whether there are any network problems. [14-01]
        Cause: Cannot find the DNS server, SMTP Server or folder for forwarding.
        Solution I sent before.
        • Sashko
          • Oct 2009
          • 110
          Descriprion from SM: SMTP Connection Failed.
          Cause: Failed to connect to the SMTP server (timeout) because the server could not be found.
