Lines on 3224c
  • daveyball
    • May 2009
    • 314
    Lines on 3224c
    Take a look at the attachement from a Ricoh 3224c does this look like the laser to you guys, it also produces them in colour sometimes as well.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Doesn't look like laser at all. PCU assembly perhaps
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Jomama46
      • 2900
      Yes, pcu or pcu cleaning
      sigpic
      A+; Network +; PDI+
      • teebee1234
        • Jul 2008
        • 1670
        • What orientation was this produced?
        • Is this sample an actual output of the counter sheet or did you scan it SEF orientation through the doc feeder to produce the lines?
        • On the actual document, do the lines go to the very edge of the paper. Your sample indicates that they stop short of edge, but that may just be due to the pdf conversion.
        • If the actual print has the lines stopping short, then it would be dirty glass slit/optics.
