Anyone know how to enter a serial number on a Ricoh / Lanier LD124c ?
  • KOPYTEK55
    • Nov 2009
    • 21
  • Jomama46
    • 2900
    CALL YOUR REP
    sigpic
    A+; Network +; PDI+
    • KOPYTEK55
      • Nov 2009
      • 21
      sc 195
      LOL I am the rep . Called Ricoh tech support and they want me to replace the NV-RAm and BICU before they will walk me thorough the procedure . Just thought I might be able to do it before investing company dollars into a unit which will be scrapped soon .
      Thanks for the feedback .
      • Eric1968
        • 2458
        The manual says it's a defective NVRAM or the BICU-board is replaced without the original NVRAM, so the answer Ricoh gives is the right one, I think.
        • KOPYTEK55
          • Nov 2009
          • 21
          Thanks for the reply . I did read that and have talked with tech support , but they would not give me the info till I replaced the BICU and NV-RAM .
          • zyqwiz
            • Jun 2009
            • 333
            If you haven't already replaced the NVRAM, why do you need to change the serial number?
            • trc
              • Jan 2007
              • 95
              you are using an NVRam that belongs to other machine???? If that , you have to change the tab placed in the scanner unit ,the machine "read" that code there.
              • RG1964
                • Jul 2009
                • 56
                On some models you have to enter the serialnumber when you've replaced a board. Even when you use the same NV ram.
                Learnt it the hard way on a MP8001
                • paperclipsandbubblegum
                  • Sep 2009
                  • 29
                  So what you're saying is tech support won't give you the procedure to enter factory service mode ? Instead they want you to replace costly parts at which time you'll still need the procedure.
                  • KOPYTEK55
                    • Nov 2009
                    • 21
                    SC195
                    Thanks to all who replied . No boards were changed prior to the code coming up . The serial number in SP5811 is scrambled . I did finally order the parts .The end user told me there was a major power outage the day before . Once again thanks and I will post the results.
                    • mahabub
                      • May 2008
                      • 12
                      input serial number
                      my friend for changing serial number do this program
                      all clear 143 then cancel button two times and hold it 3 second after that go 5811 you will found there serial number change option .
                      thanks
                      mahabub
                      • iMind
                        Vacuum Cleaning Expert
                        • Mar 2008
                        • 1116
                        thanks
                        mahabub
                        What the fu** are you crazy...
                        • Vulkor
                          • Jun 2009
                          • 942
                          Changing serial number still does not fix the Counter.
                          • Jomama46
                            • 2900
                            and why would you want to f*** with the sn if your objective wasn't really the counter? Please, wake up and smell the ozone
                            sigpic
                            A+; Network +; PDI+
                            • Vulkor
                              • Jun 2009
                              • 942
                              Personally I hate changing serial number it won't change the counter. Yes you can zero counter. It isn't ethical, but doing a mem clear before per Savin instructions has done this. Sucks too for the billing people.
