I noticed the developer section does not rotate. There is a clutch in the back that may have gone bad. Is this the problem? Any help is appreciated. Thank you.
Aficio 1035 error code 395
Tags: 1035, 395, aficio, aficio 1035, code, connections, developer unit, development unit, error, exceeded, forgot, lef, operated
SC 395
SC395 Development output abnormal
A development bias leak signal is detected. High voltage output to the
development unit exceeded the upper limit (65%) for 60 ms.High voltage supply board defective
Poor connection at the development bias terminal
Poor connection at the high voltage supply board
Same error SC395 on same machine
Have the same problem on a Savin 2535 but in my case removed the Developer Unit & Drum unit for cleaning the Exterior ressemled and now have a SC395 error. cked the DEv conections allOk, cked the Connections where the Dev and wall make contacts for Dev it looks ok, making contact ok. Removed the BIAS connector from the HV PCB in the to eliminate the circuit to the Dev unit (with the BIAS connector disconnected) made a copy and the same problem occured. I think its a bad High Voltage PCB. can someone give me some feed back of my problem??
