sav-4075/af-2075 w-sc345
  • T911
    • Jun 2007
    • 628
    went back with the dev power pack but no luck, checked my connections ok, dev unit not locked up. ideas appreciated. thanks T
  • tekcopyer
    • Nov 2009
    • 35
    Try to change the receptacle connecting to development unit, located at back of the machine.
    Everybody wants to go to heaven, but nobody wants to die.
    • aabarnes1
      • Mar 2009
      • 620
      Watch out for the loom coming out of the gw controller at the rear, this can rub off the fly wheel causing this code, also if the dev unit is not in correctly it will arc causing this sc. Make sure the dev unit sits correctly onto that pin as you look directly in line with it as you slide it in, you may need to turn the knob slightly to allow it all the way home and then to the left slightly.
      Grant me the serenity to accept the things I cannot change.
      • Frank12
        • Nov 2008
        • 77
        take out the development motor & check the bushing gear
